V&H 4 into 1 Megaphone exhaust
  • leorider
  • leorider's Avatar Topic Author
26 May 2009 16:50
#294204
I have been fixing up my 78 KZ650 B2 and one of the last things I need is an exhaust since the original one literally has holes in it from rust. I have seen one of those Vance & Hines 4 into 1 on a bike once at a show and it looked real nice. I wanted to see if anyone had any experiance jetting the bike with that pipe. I have the emgo pod filters and I do remember bumping up the pilots to 17.5 but I forget what the mains are. I THINK they may be 117 or 118. It does have a little bit of a bog when I crack open the throttle from 3/4 to WOT.
78 KZ650B
  • leorider
Re: V&H 4 into 1 Megaphone exhaust
27 May 2009 17:43
#294460
Anyone!?? Come on!! someone has got to have this exhaust on their KZ650!!
78 KZ650B
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
27 May 2009 18:12
#294467
I have the 4 into 1 vance and hines on my 77 kz650, it has a 710 kit on it, and the carbs are off of a Z! 900 with the stock jetting. The bike runs flawlwss with no bogs what so ever.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • buckinrut25
  • buckinrut25's Avatar
27 May 2009 18:19
#294468
The issue may be the pods the emgo pods dont run worth a crap on mikunis if you have air box put it back on and it should run good with the pipes you may need to go to 125 mains
  • kawsakiman
  • kawsakiman's Avatar
27 May 2009 18:42
#294477
i ran 17.5's and 120's in mine before i tore it apart again.
stock 650 with a vance and hines run wide open,, 26 mikuni's and k and n filters.
  • leorider
27 May 2009 19:01
#294487
I have heard this about EMGO's that they are crap. Is it that they are restrictive or just flow way to much? I cant tell. I would put the stock airbox back in but its such a PITA to work on those carbs with that box.
78 KZ650B
  • oldkaws4ever
27 May 2009 19:03 - 27 May 2009 19:04
#294488
I have EMGO pods on my z1, i found that if you super glue the rubber boot to the chrome pod housing were it slides in they run alot better.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 27 May 2009 19:04 by oldkaws4ever.
  • buckinrut25
27 May 2009 19:12
#294493
I think the issue with emgos are that the rubber blocks the air flow port that opens the needle valve and will not let it get enough air in the port to fully raise the needle which is why most of the issues with them are on higher rpm range some poeple try to trim the rubber around the ports and then glue the rubber to the chrome to replace the strength i would either drop the cash for k&n filters or deal with the air box
