- Thank you received: 2098
idle problem
27 May 2009 07:11 #294345
by Patton
Replied by Patton on topic idle problem
And remember to wear protective glasses, especially while blasting with carb cleaner spray.
Good Luck!
Good Luck!
- Davestradamus
27 May 2009 11:37 #294403
by Davestradamus
Replied by Davestradamus on topic idle problem
to do:
empty tank and inspect for debris
take fuel lines apart and clean
replace inline fuel filter
remove carbs and clean using spray cleaner
i have some lucas injector cleaner, i might use a couple ounces in the first good tank of gas.
any other ideas?
any other ideas?
- timebomb33
- Thank you received: 10
27 May 2009 11:43 #294406
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic idle problem
make sure you use compressed air the carb cleaner will soften up any deposits or blockages and the air pressure will blow them out.
