KZ1300 fouling plugs on 1 & 2...runnin' like crap!
- fullbore
Pulled all the plugs everything looked good except 1 & 2. Cleaned them and moved them to other cylinders and went for a ride. The new plugs in 1 & 2 were fouled again?
I am thinking weak spark on those 2 I guess? It looks like they are on different coils so I am thinking plug wires? I don't know?
__________________
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- fullbore
- killerkaw
- MFolks
- Thank you received: 540
- fullbore
- killerkaw
- Thank you received: 2098
Good Luck!
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- KZQ
- Administrator
- Thank you received: 1415
I do not like the GM coil pack.
I'm with otakar on coil packs, they're just not a good fit electronically.
I tried it for a few rides but soon became concerned for the electronics since the resistance is so different from stock. Typically .8 OHMS
I wrote an article about it here: CoilPacs
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- KZQ
- Administrator
I try to remember to shut off the fuel about a mile out and drain the bowls if I forget.
I recently fired up my injected 1300 and ended up living with gasoline fumes for the next three days in the shop as the pressure drained off. I'm sure that the # 1 & 2 cylinders are soaked because of the dribbling through the injectors. I'm going to add a pressure bleed off line between the manifold and the tank return line with a little valve in it so that I can just dump the pressure when I shut it down.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- otakar
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
