- Thank you received: 1
popping thru exhust when i let off throttle
- 76 LTD
24 May 2009 16:47 #293733
by 76 LTD
Replied by 76 LTD on topic popping thru exhust when i let off throttle
Before you tear the carbs apart try changing the exhaust O rings in the head a small exhaust leak will cause your problem.
- killerkaw
25 May 2009 14:05 #293919
by killerkaw
Replied by killerkaw on topic popping thru exhust when i let off throttle
well my buddy had some pilot jets that he drilled out to the equivelant to the #50 so i figured why not try them i put them in and set pilot screw back to the 1 1/2 turns that the carbs were at before i messed with them it took away all the popping running great thanks for the help
