- Thank you received: 6
vm 26 vs vm 28 w/ acc pump
- will61310
20 May 2009 05:00 #292835
by will61310
...1980 LTD 1000...
vm 26 vs vm 28 w/ acc pump was created by will61310
any advantage to swapping out the stock carbs on my 77 ltd w/ a set from a 79 mark 2? is bigger better 26mm - 28mm and do the acc pumps make a big difference- i know what theyre for.. its just that i may do a 1075 later and am not sure the 26s will be enough carb, and im not wealthy enough to buy a set of 29 smoothies
...1980 LTD 1000...
- timebomb33
- Thank you received: 10
20 May 2009 08:55 #292865
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic vm 26 vs vm 28 w/ acc pump
bigger is better in your case grab the 28's they wll work well for anything up to about 1100 cc's. much better set-up than the 26 mm carbs
- keith1
- Thank you received: 2
20 May 2009 18:36 - 20 May 2009 18:36 #292978
by keith1
Replied by keith1 on topic vm 26 vs vm 28 w/ acc pump
timebomb33 wrote:
timebomb is 100% correct...been there , done that !!!
bs34 s would be on the radar also....cheaper alternative to 29 smoothies.....
Last edit: 20 May 2009 18:36 by keith1.
