help with jetting kz1000 AND pipe diameter
- 93dakman
19 May 2009 11:16 #292677
by 93dakman
help with jetting kz1000 AND pipe diameter was created by 93dakman
First I want to say that I have spent for eva looking through the forums and searching for my answer. If you guys know of a link that has the info im looking for that would be cool too.
I found out about this site over a year ago and have just been lurking for some time, gathering info and what not.
My project is a 1977 kz1000. I have been restoring it from the ground up and giving it my own twist on some parts since last fall. I have the vm26's on it. Im running uni individual filters (always loved the foam over k&n) stock headpipes mated to dual megaphones. I dont want to run open megs so im going to put glass wrapped baffles inside. What inner diameter baffle do you think would provide the best all around power for the 4-2 setup.
Now about the jetting. With the pods, exhaust, no airbox and vm26'ss what do you all think my setup should be. I have picked up four 117.5 mains and moved the needle to the third slot from the top. Im not sure where to start at with the pilot jet or the mixture screw. Im running with stock gears. Any help will be GREATLY appreciated. Thanks in advance.
- timebomb33
- Thank you received: 10
19 May 2009 12:31 #292687
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic help with jetting kz1000 AND pipe diameter
i use 20 pilots myself in my 26's and 117.5 mains as far as baffle goes can't help you.
- 93dakman
19 May 2009 20:23 #292796
by 93dakman
Replied by 93dakman on topic help with jetting kz1000 AND pipe diameter
thanks, ill try those. do you know where your needles are clipped at?
- timebomb33
19 May 2009 21:54 #292806
by timebomb33
third position
