petcock on 82 ltd1000
- brianrae33
17 May 2009 15:33 #291951
by brianrae33
1982 kz1000ltd
petcock on 82 ltd1000 was created by brianrae33
have recently switched to pod filters and there is a hose running from backside of petcock that i've plugged..seems to only flow fuel in prime position now...standds to reason i guess..have to hoses i've capped coming from 1 and 4 carbs..should i link the hose from petcock to these or what??
1982 kz1000ltd
- Buda
17 May 2009 18:34 #292135
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic petcock on 82 ltd1000
I just changed out the petcock for a manual one. Takes care of the need for those vacume lines.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- roy-b-boy-b
- Thank you received: 103
17 May 2009 18:49 #292171
by roy-b-boy-b
Replied by roy-b-boy-b on topic petcock on 82 ltd1000
Put the vacum hose from the petcock to the vacum port on one of the carbs. Should be no.2 i think. The prime is suppose to go to carbs.
I use the prime line on my bike as the diaphram leaks. Roy
