83 GPz1100 FI Problem
- gaillarry
1977 KZ1000
1985 Gpz750
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
By the way. Two codes you do not want to see is 2-long & 1-short and also 3-long & 1-short. Both of those codes mean that the problem is internal to the ECU and the unit must be replaced. This is not an easy nor cheep proposition these days. It was never cheep to begin with.
If the ECU is throwing the codes Otto described, I have a good ECU I'd be willing to sell.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- gaillarry
1977 KZ1000
1985 Gpz750
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Mcdroid
- Gone Kwackers
- Thank you received: 318
One thing I do not know is the ECU interchangeability. I am quite sure that the 1982 will accept the 83-84 ECU but the 85 Turbo ECU is completely different. I do not know id the earlier 80-81 ECU units will work in the later bikes.
Good point Otto...I also have wondered about that. When I get my 1982 fired, I have ECU's for the 1981, 1982, and 1983/4 year models. I intend on trying them all on a running 1982.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
en.wikipedia.org/wiki/Kawasaki_GPZ1100B1/B2
Read it threw and it should give you a independent unbiased insight.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Crazyfor84
1984 Gpz1100
Targa smoked screen
Targa Lower
V&H Chrome Megaphone Pipe
1170 Wisco pistons
EBC Clutch
50,000 miles and still going strong!
Origonal Owner
- The Gringo
Hello, I was reading your thread on the FI Module problem on the 83 Gpz . I have an 84 Gpz1100 that I've owned since new and has 50,000 miles on it and twice I have had the same problem. It turned out to be the temp sensor that is connected to the head. Definatly check the ECU blinking green lamp for any codes. Then check the temp sensor for a broken wire or replace it, you never know. I hope this helps. Take care
If it turns out to be a temp sensor I have a new one of those as well. Both the sensor and the ECU are off an 84 GPZ1100 that I converted to carbs.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
