DynoJet install, Drilling out the Slider?
  • Johnny Red
  • Johnny Red's Avatar Topic Author
  • 80 KZ750 H LTD
Re: DynoJet install, Drilling out the Slider?
12 May 2009 14:43
#290579
photo was to big. here is the photo.
  • otakar
  • otakar's Avatar
12 May 2009 15:00
#290583
OK than I will than presume that these are KEIHN carburetors and not Mikuni. They are the only Goofy company that puts the lift holes at the intake side of the slide. In this case, I believe that they should both be drilled out. The drill they give you is only a .098". On the Mikuni carbs for the same bike they give you a .116 drill. this is for a single hole.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Johnny Red
  • 80 KZ750 H LTD
12 May 2009 15:03
#290585
Ok so to comfirm, I will drill out both holes with the drill they gave me.
  • otakar
  • otakar's Avatar
12 May 2009 15:14
#290588
Yes, because the holes are evenly spaced off the centerline
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Johnny Red
  • 80 KZ750 H LTD
12 May 2009 16:38
#290623
Install completed! Works like a champ! sounds and runs the best it ever has!
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
12 May 2009 16:41
#290624
followed along good job guys!
otto your a top guy for helping red through this A++++ ;)
The following user(s) said Thank You: rosko77
  • rosko77
  • rosko77's Avatar
08 Aug 2019 13:00
#808930
thank you i just got the dyno stage 3 kit as well and had the same question
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
17 Aug 2019 12:08
#809328
For some reason, I'm unable to view the pics, says "The request content cannot be loaded"
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
18 Aug 2019 01:18
#809380
Somewhat confused, so does this work on the 1982 GPz1100's, too?
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
19 Aug 2019 09:51
#809468
My Mikuni BS34's have two holes in bottom of slider, one is for the needle and the other I assume is an air hole. Is it the air hole that needs to be drilled??
1982 KZ1100D1
  • loudhvx
  • loudhvx's Avatar
19 Aug 2019 13:36
#809486
Yes the air hole is what gets drilled. It is the one that is off-center. The center hole is for the needle.
But you don't necessarily have to drill the hole. Enlarging it just makes the slide jumpier. That is. yes it will go up faster, and if the engine can handle it, it might make for a bit quicker acceleration, but it also makes the slide more sensitive and "bouncier", meaning it moves up and down during engine pulses during intermediate throttle positions.
If the bike is having trouble running, then I would not drill the slide as a remedy. I don't think it would ever be the problem. Many people never drill the slide so they can go back to stock. It just means the slide opens a tiny bit slower than necessary.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
20 Aug 2019 05:56
#809532
I'm just a little confused as to what it will take for my 1982 GPz 1100 w/ 4 into 1 V&H megaphone (no baffel) and Pod filters to smooth out that first 1/8th throttle, ...I read somewhere on here, ... shim stock needles .040" to .050", ..along with 40 pilots and 140 main jets. Ethan over @ MikeXS said to put a shim P/N SU009-395 under the needles and it should solve the issue.
Just to clarify, does shim go under the needle's clip (tapered end pointing down), then into slider??
1982 KZ1100D1
