vm28 accelerator pump
- Bicycle Lee
12 May 2009 11:47 #290534
by Bicycle Lee
1978 KZ1000 police
vm28 accelerator pump was created by Bicycle Lee
So I've put thee vm28's back together and I was just wondering if there was any sort of specs on where the accelerator pump should be adjusted to? Or anything to do with the accelerator pump I have to keep in mind.
Up until now I've only used bs34's so this whole pumper carb thing is kind of a trip to me...
1978 KZ1000 police
- sbulla
- 1980 KZ1000 LTD
12 May 2009 13:33 #290557
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Replied by sbulla on topic vm28 accelerator pump
When I put mine back together, seems I remember seeing instructions to leave about 3/16 of an inch of thread showing under the nut.
That's where mine is and it's working. (at least THAT part of the carb is)
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Bicycle Lee
13 May 2009 00:17 #290737
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic vm28 accelerator pump
thanks... I'll tinker with it when I test fire the motor and let you all know what I find
1978 KZ1000 police
- fullbore
13 May 2009 14:25 #290862
by fullbore
Replied by fullbore on topic vm28 accelerator pump
my book says 10mm distance from nut to end of thread although I don't have mine adjusted that way?
- Bicycle Lee
13 May 2009 15:03 #290867
by Bicycle Lee
1978 KZ1000 police
10mm from the end of the thread? To the end of the little nut? Or to the start of the little nut? And 10mm from the end WHICH direction? haha
1978 KZ1000 police
- fullbore
14 May 2009 06:52 #291058
by fullbore
The book says 10.7 to 10.9mm from bottom of nut to end of thread which I interpret as roughly 10.7 to 10.9mm of thread showing
- JMKZHI
- Thank you received: 48
14 May 2009 07:13 #291063
by JMKZHI
Replied by JMKZHI on topic vm28 accelerator pump
You should be able to test the functionality of the accelerator pump w the carbs off the bike. Put 'em in a stand, supply some fuel & prime the pump ciruit. Actuate the throttle pulley vigorously: fuel should squirt out the pump nozzles, straight back without hitting the carb bore walls. If the fuel dribbles out or squirts crooked, there may be debris in the nozzles or the pump circuit.
