where do i start to ajust the mixture screws
- theoutdoorsman1972
12 May 2009 11:12 - 12 May 2009 11:23 #290530
by theoutdoorsman1972
where do i start to ajust the mixture screws was created by theoutdoorsman1972
can somone tell me how i should go about getting the adjusted properley on a 1978 kz1000 b2
Last edit: 12 May 2009 11:23 by theoutdoorsman1972.
- Mcdroid
- Gone Kwackers
- Thank you received: 318
12 May 2009 11:42 - 12 May 2009 11:47 #290533
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic where do i start to ajust the mixture screws
Well, assuming you have stock VM26 carbs, then there is only a single screw (on each carb) that is adjustable, and this is the pilot air screw. If your bike has never been adjusted, then there might be a plastic cap covering the slotted head of the pilot air screw. If so, then you'll have to remove this cap...tighten the air pilot screw till it is lightly seated and back it out 1 1/2 turns. This is a good starting point. If you have non-standard carbs, it will depend upon what you have on the bike.
Edit: If you are speaking of changing the mixture jets, I strongly encourage you to get a Kawasaki shop manual for your bike, figure out what carbs you have, and then decide if you actually need to change jetting based upon what exhaust system and air intake system you have.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 12 May 2009 11:47 by Mcdroid.
