what carbs do i have on my 1978 kz1000 b2 ltd
- theoutdoorsman1972
- Thank you received: 2098
i,m sure they are stock ,but there are no numbers anywhere on them,also what is the float hieght or better yet how much feul should be in them ,i made a tool with clear tubing to hook up to the drain ,but dont know how much should be in them
2-4mm below bottom edge of carb where the floatbowl connects.
In other words, 2-4mm below floatbowl gasket.
Good Luck!
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
West Linn, OR
- donthekawguy
- Thank you received: 8
Good Luck!
You probably have 26's on it. The ones pictured are 29's but I think they have the same float height.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
