oops leaking fuel
- Ethercan
I cannot seem to find anywhere that sells the straight union tubes only the the fuel inlet T tube. can someone point me to a vendor which might be able to help.
Many Thanks
- PLUMMEN
- Thank you received: 104
- Ethercan
- PLUMMEN
- Bluemeanie
- Thank you received: 14
new owner new to the forum. I bought a 78 kz650 sr that ran like crap after reading about it here I cleaned my carbs but during reinstallation I tore the rubber on one of the straight tubes which joins the carbs together:( , and now it is leaking there.
Many Thanks
Are you talking about the three small fuel lines connecting the bowls? Are they "pumper" carbs? I used (4mm if I remember) fuel line, fit snugly without clamps.
- RonKZ650
- Thank you received: 240
- Ethercan
I was able to order them after all thanks
