- Thank you received: 1
Air screws and pods
- violentvintagecycles
10 May 2009 10:03 #289867
by violentvintagecycles
Air screws and pods was created by violentvintagecycles
Hey all, putting the carbs back together, got the plugs drilled out for the air screws. Im running pods, stock exhaust, what would you guys tune the air screws too? Stock was 2.5 turns on all. 82 kz550a3.. Tk carbs..
10 May 2009 16:42 #289958
Replied by violentvintagecycles on topic Air screws and pods
no one?
- gane
10 May 2009 16:59 #289973
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Air screws and pods
start w/ stock, bring to temp, idle mix will probly be lean.making it easier to hear when adjusting individual mix screws in/ out. color tune or ega would be optimum. however "ear-balling"or electronic tach can be used.even from factory there are usually differences in individual settings. just pods seldom require changing pilots in clean carbs, but possible.luck G
