worn throttle shaft - kz 400
- Paul K
09 May 2009 08:28 #289361
by Paul K
worn throttle shaft - kz 400 was created by Paul K
what can be done to remedy worn throttle shafts and the bores that the shaft rides in? i think i could re-plate the shaft, however, is there a way to re-bush the bores? i am experienceing internal vacuum leaks resulting from the air leaking around the butterflies and around the worn throttle shaft to bore areas as well as some vacuum leakage from where the shafts stick out the shide of the carbs.
these are the carbs found on a '76 kz 400 d3 model with the keihin piston cabs (non-diaphragm).
thanks,
paul k
thanks,
paul k
- GPz550D1
- Thank you received: 22
09 May 2009 16:39 - 09 May 2009 16:42 #289465
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic worn throttle shaft - kz 400
I am sure that it could be done, but it might be expensive. May be easier to look for some good, used carburetors. Also, you may have vacuum leaks at the rubber mounting holders on the engine side of you carburetors. If yours are original, look for cracking. That could be your problem.
Robert
Robert
1981 KZ550-D1
Last edit: 09 May 2009 16:42 by GPz550D1.
- MFolks
- Thank you received: 540
09 May 2009 20:57 #289635
by MFolks
Replied by MFolks on topic worn throttle shaft - kz 400
If you really want to keep the carbs, I'd try the industrial bushing suppliers for Metric bushings and then find a machine shop to do the work for you.
Try here:http://www.mcmaster.com/#metric-bushings/=1t27im
- Paul K
10 May 2009 00:18 #289734
by Paul K
Replied by Paul K on topic worn throttle shaft - kz 400
thanks robert, however vacuum leaks around the rubbers aren't the problem this time. the throttle shaft has noticeable play in it and a resulting change in rpm when moved.
thanks for the bushing link MFolks.
pk
pk
