A couple of carb ?'s
- sbulla
- 1980 KZ1000 LTD
08 May 2009 20:38 #289212
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
A couple of carb ?'s was created by sbulla
I just acquired some J8-5DL31jet needles that I was told would work with my VM28SS (with accel pump) carbs.
Need a second opinion from you guys to confirm this. Will the stock needle jet work with them?
Also, I'll be changing from the stock airbox (with K&N element) to K&N pods and running a Kerker 4-1 exhaust with a packed (long) baffle. Anyone know the sweet jetting combination for this set up for a stock engine?
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- timebomb33
- Thank you received: 10
09 May 2009 01:26 - 09 May 2009 01:29 #289320
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic A couple of carb ?'s
depending on your local elevation try 17.5 or 20 pilots and the needle in the third position and 115 0r 117.5 main jets. i pay no attention to the needle numbering system that mikuni has so those numbers don't mean much to me but unless there is a marked difference between your stock needles and the ones that you just got i would stick with the stockers and experiment with needle height's you can usally get very close with the stock stuff.
Last edit: 09 May 2009 01:29 by timebomb33.
- sbulla
- 1980 KZ1000 LTD
09 May 2009 07:22 #289349
by sbulla
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
Replied by sbulla on topic A couple of carb ?'s
timebomb33 wrote:
Thanks for the reply. Elevation is 1000' here and, the reason for the new needles is that, the last time I had the carbs apart, I noticed a couple of 'em had pitting down near the tip and weren't exactly smooth.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
