Carb help please
- clc
08 May 2009 06:38 #289014
by clc
Carb help please was created by clc
These carbs were rebuilt 2 time this week with a new accelerator pump. 1981 kz650. Accelerator pump is new, every gasket and oring has been replaced.Bike will run with the choke on or off. The bike will die if you give it throttle too fast. Slow jets are 17.5 main jets are 112.5.
exhaust are about three feet long straight pipes with pod filters.
Thanks for the help.
- Bicycle Lee
08 May 2009 14:41 #289103
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic Carb help please
are you sure this is a carb problem? Are you getting good spark on all plugs? Is your timing on? Are your coils good?
1978 KZ1000 police
- wildwilly30
08 May 2009 19:03 #289177
by wildwilly30
1977 kz1000 chopper
1974 honda cb750k chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
1981 yamaha 650 special
1983 kawasaki vulcan
1977 hd sportster chopper
1987 honda vt1100c shadow
Replied by wildwilly30 on topic Carb help please
vacuum leak?
1977 kz1000 chopper
1977 kz1000a1
1977 kz900a5
1978 kz650b2
1982 kz750r1 gpz
- Bluemeanie
- Thank you received: 14
08 May 2009 21:03 #289245
by Bluemeanie
Replied by Bluemeanie on topic Carb help please
wildwilly30 wrote:
Good point.... check your carb holders to make sure they are not leaking air.
vacuum leak?
- PLUMMEN
- Thank you received: 104
08 May 2009 21:04 #289248
by PLUMMEN
Replied by PLUMMEN on topic Carb help please
what did it run like before therebuild,better or worse?
