air hoses
- My1stKZ750
and i noticed the hoses going inbetween the 2 valve cover air valves are all messed up ..so i had a piece of heater hose laying around and i ran it from one side to the other.Is this OK? also what do i do with the small diam. hose going to the carbs..
thanx mike
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- JR
- Thank you received: 449
I have to admit that I have never seen these
I think the small diameter hose going to the carbs (number 2 carb ?) is probably a vacuum line and if so then should be connected to a matching diameter outlet on the petcock.
- My1stKZ750
- My1stKZ750
- JR
Are there similar vacuum ports on yhe 2 and 3 carbs ?
On my bike I have little rubber vacuum caps on the brass vacuum nipples on the 1, 3 and 4 carbs and on #2 there is a narrow diameter hose which goes to a matching diameter nipple on the petcock. Those four nipples should be either capped or connected to something. Should'nt be left open.
Up here we did'nt get all that stuff with hoses running across the head and into the airbox and so on so it's hard to visualise your setup.
Have fun
- l0g1c
- Hanging on for dear life.
If you still have your airbox, look for a hole on the front of it, and plug that as well. That's where those hoses were originally routed.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- franknsr
I have an 1980 KZ750 LTD 4cyl. I'm keeping stock airbox, but I recently had tank(fuel) off.
thanx mike
LOL, that's exactly how I plugged mine.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
