Homemade float bowl gaskets ?
- Requiescat
The float bowl gaskets were not in good shape after I got some carb cleaner on them when I was cleaning the siezed carbs. Could a bad float bowl gasket cause the problems, and could I make my own gaskets with some gasket stock and an exacto knife? I don't want to spend $100 on carb kits for a bike with 5000 miles on it.
I have new airbox to carb boots coming, they are hard and almost caused me to swear when I was putting the carbs back on the bike. I was going to check the carb to engine boots when I put the new airbox boots on.
Do I need to have a look at the ignition advance mechanism?
1980 KZ750H LTD more fun than a barrel of monkeys.
have had:
1982 Suzuki GS400L (wadded by an ex friend).
1982 CB 750 Nighthawk(sold to a friend).
- Thank you received: 2098
With the help of this forum, my 1980 KZ750LTD is running . Not running well, but running. It won't idle below around 2000 rpm and has little power off the line.
Z1e shows float bowl o-rings (not gaskets) for 1980 KZ750-H LTD, with a set of 4 for under $16.
The o-rings are reportedly fragile and often replaced during reassembly.
I don't suspect either failure to idle down or lack of power off the line is resulting from leaking floatbowls.
Would use strobe type timing light to assure correct ignition timing and correctly functioning advance mechanism. Would follow FSM instructions with regard to cleaning and lubing the advancer. .
Good Luck!
- bountyhunter
- Thank you received: 337
I made bowl gaskets before and it is definitely not worth the trouble. It takes a specil material that is gas resistant. Regular cork disntegrates and paper is not usable.
- JR
- Thank you received: 449
It sounds like not enough gas at low speed and I would think carb related. When I got my 750/4 six years ago I had a lot of carb problems when under 3,000 rpm. I took them off and cleaned them ..........again and again until finally I decided to clean as thoroughly as possible. It's often not enough to soak them in cleaner. Only after I totally dissambled them, took out every jet and poked every oriface no matter how small with a stiff bristle or 50lb nylon fishing line or guitar string (carefully) until I was sure it was clear and then finally blew everything out with compressed air, only then did my problems go away.
Also, and assuming the carbs are Keihin CV34s, dont neglect the transition holes. To find them look into that end of the carb which faces the motor. Lift the throttle flaps and look up. The hole nearest the opening is from the air mix screw. Just behind that you will see 3 tiny holes. These need to be clear or motor will stutter or just generally bog under 3,000rpm.
Finally, make sure the fuel level in the float bowls is where it should be - about 1/4 - 1/8 of an inch below the bowl gasket.
Of course I could be totally out to lunch here and maybe the new carb boots will be the fix when you get them
Good luck
- Requiescat
I thought I had cleaned all of the holes, I'll do it again and make sure I get all of the holes. These carbs were seized solid so I'm sure those holes are blocked if I didn't see them.
The bike seems to run well in a narrow range of engine speed, low end bogs and after 5000 or so RPM it doesn't feel right.
Thanks for your help.
have had:
- Bicycle Lee
so I have float bowl gaskets that came in a whole KZ1000 gasket set. I tried fitting them in and they are just a little too large (we're talking fractions of millimeters). Is it bad to maybe cut them to fit? I'd rather not have to buy a whole new set of them.
1978 KZ1000 police
