Idle Jet Issue
- athlonwirez
04 May 2009 07:53 #287776
by athlonwirez
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
Idle Jet Issue was created by athlonwirez
My father-in-law and I adjusted the valves on the 1978 1000LTD that he is going to give me. Soon after that I had the carbs off and was blowing out the main and idle jets. When I took one of the idle jets out the whole jet did not come out. It had broken, or was already broken, off just past the threads. I don't know what the section that has the tiny holes is called, but that is what is still stuck in the body of the carb. It has been impossible to come out. We were able to still blow compressed air through the hole on the intake of the carb, so it's not blocking air flow. We put it back together and it idles and runs fine. I was just wondering if anyone has had this happen to them, and how they finally got the remainder of the broken jet out. Is it possible to carefully drill it out?
- anarki650
- Thank you received: 5
04 May 2009 08:11 #287783
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Idle Jet Issue
Use a reverse cut drill bit that's not going to dig into the threads for the idle jet. That's your best bet to extract the broken off piece. The reverse cut has the potential to act like a screw extractor and get the offending piece to back out of the threads without having to drill it all out. Whatever you do, make sure you don't screw up those thread or you'll have a hell of time ever getting a pilot jet back in that carb body.
09 Kawasaki ER6n
Omaha NE
- athlonwirez
04 May 2009 08:16 #287784
by athlonwirez
Replied by athlonwirez on topic Idle Jet Issue
Would a regualar drill bit not work, because the portion that is broken off is beyond the threads?
- Bicycle Lee
04 May 2009 08:21 #287786
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic Idle Jet Issue
wow... sounds like quite a pickle....
if it idles and runs fine my suggestion would be to leave it. Don't worry about it until you have to or else you could screw up those threads like Anarki is talking about. That's a very small hole with very small threads and I, for one, wouldn't trust my hand in drilling it out.
that's just my two cents.
1978 KZ1000 police
- athlonwirez
04 May 2009 08:49 - 04 May 2009 08:56 #287796
by athlonwirez
I'm not too concerned about it right now. I'm just digging for ideas. Another thought I had was to use the pilot jet portion that came out, and use it as a guide to get the stubborn brass out, without messing up the threads. The circled area is the portion that is broken off in the carb body.
Last edit: 04 May 2009 08:56 by athlonwirez.
