Coil Problem?
04 May 2009 07:29 #287769 by 2bskor
Coil Problem? was created by 2bskor
This morning I was going on the highway starting to accelerate to about 100kms when the bike lost power. It felt like only two cylinders were firing. When you come to a stop it stalls but if you throttle it up a bit and restart it it will run but boggy. I got home and did the water test on the pipes and #2,3 are not hot at all. #1,4 are hot as hell.
I am thinking it is the coil as they look original. I am probably going to replace them but how do you check them and if I replace them how do I know what OHM they are. They are black with no markings on them.
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
04 May 2009 07:56 #287779 by PLUMMEN
Replied by PLUMMEN on topic Coil Problem?
which bike,im guessing mkII ?
04 May 2009 08:42 #287791 by 2bskor
Replied by 2bskor on topic Coil Problem?
1979 kz1000st or kz1000e1
04 May 2009 08:44 #287792 by PLUMMEN
shop manual lists test procedure for coils,im guessing theyre 3 ohm B)
04 May 2009 08:57 #287797 by 2bskor
The ohm is what I'm not sure of
04 May 2009 10:13 #287813 by Jack
Replied by Jack on topic Coil Problem?
Yes,the coils should be 3 ohm. If you're replacing them you might want to go to Z1 Enterprises and look at the Dyna coils- 3 ohm will be green in colour.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
04 May 2009 11:09 #287821 by MFolks
Replied by MFolks on topic Coil Problem?
You can use a multimeter set on OHMS to check the coils, just disconnect the primary(smaller wires) and put the meters probes on the primary wires terminals.
If the coils have cracks in them(a sign of age or over heating) it's time to replace them. I'd consider replacing the sparkplug leads(or High Tension cables as some people call them)too.
04 May 2009 12:40 #287839 by Patton
Replied by Patton on topic Coil Problem?
!979 KZ1000 model introduced electronic ignition with igniter, using 1.2-1.9 ohm coil primary and 12-18k ohm secondary (which would be the oem or stock coils).
If Dyna-S ignition is later fitted, the green Dyna 3 ohm coils are appropriate and the igniter is no longer needed.
There are several reasons for insufficient spark, even with a perfectly good coil.
Good Luck! :)
04 May 2009 14:21 #287890 by JR
Replied by JR on topic Coil Problem?
Patton said
"There are several reasons for insufficient spark, even with a perfectly good coil"
Absolutely !
dead side of points or pickup coils. bad wires, bad or loose connection. dud plug caps, dud plugs, water/rain on the electrics etc etc etc.
look for the cheap fix first :)
good luck
04 May 2009 18:50 - 04 May 2009 18:54 #287989 by 2bskor
Never and I mean NEVER overlook the obvious like a broken wire !!!!! Yep a little solder and my hooptie and I are a ridin again. Thanks for all the tips !!
I want to put new coils and probably do the WG mod someday soon but there are different coils and dyna ignition etc. I know I don't have points as there is a plate with two magnet looking things attached to it inside the timing cover. Do you have to replace that or just coils do you keep your ballast resistor?
Last edit: 04 May 2009 18:54 by 2bskor.
04 May 2009 20:29 #288028 by MFolks
The Dyna S replaces the IC Igniter, and the pick up coils.
New ignition coils would be an upgrade and yes, the resistor would be removed using the Dyna S system.
04 May 2009 20:42 #288036 by 6leafclover
Replied by 6leafclover on topic Coil Problem?
I have the same problem on the exact same bike, it did it when i brought it out of storage this year and then once i rode for awhile it went away and worked fine untill the other day when the 2,3 went out again and i cant figure it out, when i brought it out of storage it was like the 2,3 coil needed to heat up before it would work. those cylenders are completly out at the moment and no matter how much i ride and how warmed up it is they just wont start to fire but my coils are pretty new they were put on the bike just before i bought it last fall, I have the recept from the PO to verify, dident mean to hijack your thread, I just thought it was odd the same problem on the same bike.
1979 KZ1000-E1/ST
Madison, IN
