1st time kz owner with problems
- pitblue/kz
02 May 2009 17:28 #287261
by pitblue/kz
1st time kz owner with problems was created by pitblue/kz
i need help my baby is sick when we ride she will miss when i level out at 65 to 75 but not alot below and will not idle below 2k this is my first kz and i dont have alot of money to put it in a shop i need advise also i live in jacksonville fl and would like to ride with other kz riders
- fochtup1
02 May 2009 17:35 #287262
by fochtup1
Replied by fochtup1 on topic 1st time kz owner with problems
i would pull the carbs and check to make sure all jets are clean. pilots, mains.
- pitblue/kz
02 May 2009 17:56 #287266
by pitblue/kz
Replied by pitblue/kz on topic 1st time kz owner with problems
i did that today. Cleared up for a little while and is doing it again.
- Thank you received: 2829
02 May 2009 18:11 #287271
by 650ed
Replied by 650ed on topic 1st time kz owner with problems
If cleaning the carbs helped and then the problem started again after a little while, is it possible there is rust or some other crud migrating from the tank to the carbs? You may want to put in a fuel filter (if it doesn't have one) and clean the carbs one more time to see if the problem stays gone. Ed
- pitblue/kz
02 May 2009 18:21 #287274
by pitblue/kz
i have 2 now mabye i'll get new ones tommorow will this cause it to miss at higher speeds
- timebomb33
- Thank you received: 10
02 May 2009 18:32 #287277
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1st time kz owner with problems
yes it will cause a miss if the filters aren't suppling enough fuel to the carb's make sure when you get another filter that it will flow enough fuel a small lawnmower type generally wont try find ing one thatt you can take apart and clean that has a brass washable element in it russel makes a good one that you should be able to get from places like auto zone or pep boy's.
02 May 2009 18:33 #287278
by 650ed
It's hard to say. If someting is clogging up the idle circuit I guess it's possible that it could get into other areas. When you re-cleaned the carbs, did you find any dirt, rust, or crud in there that looked like it might be causing the problem? Ed
- pitblue/kz
02 May 2009 18:49 #287287
by pitblue/kz
no it was very clean but i had a needle valve worn and i changed it the others appeared to have been done already
