Sync carb with one vaccum gauge?
- vincentmoy
01 May 2009 23:56 #287125
by vincentmoy
1980
KZ750 LTD
Miles: Unknown (speedo cable broke)
Sync carb with one vaccum gauge? was created by vincentmoy
Hi all,
I've been looking around for a carb sync gauge. I called a local auto shop and they said they only have 1 vaccum gauge.
I am wondering if it is possible at all to use only one vaccum gauge to sync all 4 of my carbs on my 80 KZ750H
Thanks
Thanks
1980
KZ750 LTD
- Old Man Rock
- Thank you received: 225
02 May 2009 05:57 #287143
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Sync carb with one vaccum gauge?
Accurately... NO!
One carb tweak (adjustment) effects the other... You'd be chasing this all over the place and to dial them in with confidence and for a specification of setting 2cm Hg between each other....
Just would seem to be impossible for any degree of accuracy...
But hey, WTF do I know for some other may have had some success in this concept....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2237
02 May 2009 08:07 #287171
by TexasKZ
Replied by TexasKZ on topic Sync carb with one vaccum gauge?
The one gauge method might just create another ax murderer. Check out the thread, "carb sync without gauges."
kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=285358
- Mark Wing
02 May 2009 15:15 #287236
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Sync carb with one vaccum gauge?
Old Man Rock wrote:
I think you nailed it, a change on one changes the others so you'd be going in circles.
Mark
Accurately... NO!
OMR
Mark
Yorba Linda Cal.
- larrycavan
- Visitor
02 May 2009 15:54 #287241
by larrycavan
Replied by larrycavan on topic Sync carb with one vaccum gauge?
That would be a very good example of "pissing in the wind".
You'll be there for ages trying to do it with one guage. Forget it. Either buy guages or have a mechanic do the job.
Larry C
Larry C
- timebomb33
- Thank you received: 10
02 May 2009 18:42 #287282
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Sync carb with one vaccum gauge?
you have to be able to see what all the carbs are doing at the same time in order to know if the change you made to one will have an effect on the others as larry put it so well with one gauge your pissing in the wind and chasing your own tail and just the dog that does you will never catch up.
