Mercury gets in the engne
- barquirt
01 May 2009 19:47 #287084
by barquirt
Mercury gets in the engne was created by barquirt
OK now what ... I was balancing the carbs and while doing so I errored and gave a big turn to a carb screw and mercury dribbled over the top of the gauage, down the tube and probably into the motor. I shut everything down and pulled the carb rack I could see some shiny little drops in one of the intakes.
Will my motor go whammo next time it runs? Is it a ticking time bomb? Or will it pass through the engine if it got that far?
- gane
- Thank you received: 1
01 May 2009 20:10 #287088
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Mercury gets in the engne
Barr, Relax, The amount of mercury injested will do no harm. and will eventually wind up in the lowest portion of exhaust pipe. G
- timebomb33
- Thank you received: 10
01 May 2009 21:04 #287105
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Mercury gets in the engne
it won't hurt anything if you fire the engine up again it will blow right out but now you will need a refill of mercury in your sticks.
- trianglelaguna
- Thank you received: 235
02 May 2009 07:07 - 02 May 2009 07:08 #287161
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Mercury gets in the engne
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 02 May 2009 07:08 by trianglelaguna.
- RonKZ650
- Thank you received: 240
02 May 2009 07:14 #287162
by RonKZ650
Replied by RonKZ650 on topic Mercury gets in the engne
As mentioned the mercury won't hurt. Now for the bad news though, you can't buy mercury any more so you have to go to a different type of sync tool and to get a set that even remotely works is not easy.
- Thank you received: 2237
02 May 2009 08:04 - 02 May 2009 08:08 #287170
by TexasKZ
Replied by TexasKZ on topic Mercury gets in the engne
Check out the thread, "carb sync without gauges."
kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=285358
Last edit: 02 May 2009 08:08 by TexasKZ.
