Help with putting petcock back on!!!
- KZ550NEWBIE
01 May 2009 18:22 #287051
by KZ550NEWBIE
Help with putting petcock back on!!! was created by KZ550NEWBIE
I bought a 1984 KZ550 ltd. The gas tank was not attached. The screws were missing so I ordered new ones for the petcock,fuel sensor and the tank itself. The screws don't want to go in for the petcock and sensor. The old screws won't go in either. Can someone tell me what im doing wrong. Is there a trick?
- Mark Wing
- Thank you received: 22
01 May 2009 18:30 - 01 May 2009 18:31 #287055
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Help with putting petcock back on!!!
Can you post a pic of the area your talking about. Maybe run a tap through the holes.
Mark
Oh yeah, welcome to the site.
Mark
Yorba Linda Cal.
Last edit: 01 May 2009 18:31 by Mark Wing.
- lapeerray
01 May 2009 18:37 #287057
by lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
Replied by lapeerray on topic Help with putting petcock back on!!!
Sounds like you have the wrong size screws. Im assuming the screws dont fit with the petcock off the tank. If yhey do fit without petcock than you have the wrong petcock.
- KZ550NEWBIE
01 May 2009 19:03 #287066
by KZ550NEWBIE
Replied by KZ550NEWBIE on topic Help with putting petcock back on!!!
I don't have a camera to take pix. I order from cycle parts nation. The screw matches the old one that won't go in either. Should I grease them up.The screws are going into the gas tank. These are Kawasaki OEM parts.
- gane
- Thank you received: 1
01 May 2009 20:48 #287101
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Help with putting petcock back on!!!
Newbie, A quick peruse of my micro-fich indicates sensor screws to be 5mm, and petcock 6mm. a wild assed guess is PO tried to use american bits and boogered threads.try chasing threads w/ proper taps. make sure spacing for both are correct. luck g
