1981 kz only running on choke?
- grizzlyadams
29 Apr 2009 09:41 #286213
by grizzlyadams
1981 kz only running on choke? was created by grizzlyadams
I'm a newbie to this forum, hoping to get some answer cause
I going to pull my hair. O.K. I have a 1981 kz1000j it only runs with the choke on I have upgated the wiring for the coils and completly rebuilt the carbs all brand new
carb kits and new airfilters, the carbs are all clear and
my intake boots are new. And I havn't changed my jetting
because it was running good before with this set up, 134 on the main and pilots are 37. If there is anybody with any
thoughts please let me know. thanks
- hoghaterkaw
- Thank you received: 1
29 Apr 2009 13:39 #286255
by hoghaterkaw
Replied by hoghaterkaw on topic 1981 kz only running on choke?
if you mean it ran good last year with your setup. then over the winter the pilot jets or pilot circuits have gotten plugged up.
- grizzlyadams
29 Apr 2009 13:46 #286258
by grizzlyadams
Replied by grizzlyadams on topic 1981 kz only running on choke?
the pilot circut is clear new pilot jets and I can blow throw with compress air
- hoghaterkaw
29 Apr 2009 13:52 - 29 Apr 2009 14:02 #286259
by hoghaterkaw
are the carbs on your bike Mikuni BS34's? if so did you put the rubber caps back on that cover the pilot jets?
Last edit: 29 Apr 2009 14:02 by hoghaterkaw.
- hoghaterkaw
29 Apr 2009 13:59 #286261
by hoghaterkaw
sorry i missed posted the suzuki style BS 34's use a rubber plug over the pilot jet. the kaws use a small metal plug that has a rubber 'o'ring. make sure those plugs are in and make sure that metal plug is inserted with the 'o'ring end going in first.
- grizzlyadams
29 Apr 2009 14:23 #286273
by grizzlyadams
yes and the o-rings are new
- hoghaterkaw
29 Apr 2009 14:30 #286274
by hoghaterkaw
ok but you did not say if your bike wintered over with fuel in the carbs. if so then the pilots could be stopped up. where did you feel the air coming out? thru the mains? did you try seating the pilot screws and then opening them up two full turns. also are you turning off the choke too soon?
- grizzlyadams
29 Apr 2009 14:37 #286276
by grizzlyadams
The bike did sit this winter but I pull the carbs off and
soaked them and clean all the passages and put new carb kits in all the carbs and fresh gas to. I checked around the intake boots for any leaks and didn't find any? Could it be coming throw my choke barrel? Is there an o-ring in there I haven't taken the barrels apart?
- grizzlyadams
29 Apr 2009 14:39 #286279
by grizzlyadams
Oh ya the pilot screws are all turned on 1 1/2 turns, sorry I forgot to say that before
- hoghaterkaw
29 Apr 2009 14:41 - 29 Apr 2009 14:42 #286281
by hoghaterkaw
on the BS 34 carbs there is a rubber seat at the end of the choke plunger. but you say the motor only runs with the choke on so i think the pilot circuits may still be plugged.
oh did you make any change to the idle screw?
Last edit: 29 Apr 2009 14:42 by hoghaterkaw.
- grizzlyadams
29 Apr 2009 14:45 #286282
by grizzlyadams
no on the idle screw, but on the plunger are talking about the rubber boot on the outside of it or is there one inside that I would have to take apart to see?
- trianglelaguna
- Thank you received: 235
29 Apr 2009 14:50 #286284
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 1981 kz only running on choke?
ditto on obstructions in pilots....somthing got in after or is in someplace that got skipped.....final answer 99% sure...imo...good luck...you will prevail
1976 KZ900
2003 ZX12R
2007 FZ1000
