Carburetors/Airbox tight fit.
- Requiescat
28 Apr 2009 19:34 #286094
by Requiescat
1980 KZ750H LTD more fun than a barrel of monkeys.
have had:
1982 Suzuki GS400L (wadded by an ex friend).
1982 CB 750 Nighthawk(sold to a friend).
Carburetors/Airbox tight fit. was created by Requiescat
Good Day
I've finished cleaning a rack of four from my 1980 kZ750. This bike was sitting 8 years, the carbs were siezed with laquer.
I had a b*tch of a time getting them out from between the engine and gearbox. It was snowing today, so I've put off reassembly attempt #1 until tomorrow.
Does anyone have any tips so I put these carbs back on without looking like Homer Simpson?
have had:
- timebomb33
- Thank you received: 10
28 Apr 2009 19:38 #286095
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Carburetors/Airbox tight fit.
use a heat gun and push the boot going to the air box inside the airbox until you get the carbs on the intakes properly then when you get them in place start with the inside air box boots and work you way out feed them on to the carb from inside the air box it might get a bit cramped but it does work. good luck.
- JMKZHI
- Thank you received: 48
28 Apr 2009 19:43 #286096
by JMKZHI
Replied by JMKZHI on topic Carburetors/Airbox tight fit.
Are the airbox ducts soft & pliable? If not, then it might be a good idea to go ahead & get new ones, assuming they're available. Z1Enterprises.com may have them.
- Requiescat
28 Apr 2009 19:44 #286097
by Requiescat
have had:
Replied by Requiescat on topic Carburetors/Airbox tight fit.
Thanks,
It's going to be just slightly above freezing tomorrow, the heat gun will come in handy!
have had:
- Requiescat
28 Apr 2009 19:46 #286098
by Requiescat
have had:
They are pretty hard, I'll get some new ones, It make take some time so I'll wrestle the present ones on and wait for the new pair.
have had:
- MFolks
- Thank you received: 540
28 Apr 2009 20:09 #286099
by MFolks
Replied by MFolks on topic Carburetors/Airbox tight fit.
If new parts are not available, soaking the old ones in fairly hot water will help in installation.
- Thank you received: 2829
28 Apr 2009 20:21 #286103
by 650ed
Replied by 650ed on topic Carburetors/Airbox tight fit.
While you have the carbs off and out of the way you may want to consider replacing the carb holders (the rubber tubes between carb and head). If they haven't been replaced they may have little cracks where they mate to the head which will lead to erratic idle. Ed
- flht1997
28 Apr 2009 20:50 #286110
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic Carburetors/Airbox tight fit.
what Mfolk said, but i use damn hot water and gloves, give you a few more minutes when they are squishy
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- Thank you received: 2098
29 Apr 2009 03:31 #286153
by Patton
Replied by Patton on topic Carburetors/Airbox tight fit.
In case not already found, here are links to Z1E's listings for
airbox hoses
and
carb holders
Good Luck!
Good Luck!
- Locozuna
29 Apr 2009 06:02 #286171
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Carburetors/Airbox tight fit.
Get the new hoses then fold them over when installing or removing the carb bank. Gives you about 1 extra inch of clearance which is a world of difference. They once in a while spray thew new boots with WD or silicone to keep them soft.
[img][IMG]http://i52.photobucket.com/albums/g1/scruthut/airboxboots.jpg[/img][/img]
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
