carb ports?
- steelcowboy
27 Apr 2009 16:08 - 28 Apr 2009 14:51 #285791
by steelcowboy
carb ports? was created by steelcowboy
Last edit: 28 Apr 2009 14:51 by steelcowboy.
- timebomb33
- Thank you received: 10
27 Apr 2009 22:55 #285913
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic carb ports?
can you put a picture of them up so we can see maybe it might make it clearer to everybody what port your talking about. welcome.
- killerkaw
30 Apr 2009 15:15 #286565
by killerkaw
Replied by killerkaw on topic carb ports?
i have the same port on mine it is a drain in case of a sticking float to direct fuel away from the engine may be the same on yours
- timebomb33
30 Apr 2009 15:56 #286580
by timebomb33
that wont be a drain it will be a vent, it's a pretty good chance the reason the cap is on it is that fuel is puking out of it if that is the case you will probably need to replace the float valve assembly.
- steelcowboy
01 May 2009 16:10 #287021
by steelcowboy
Replied by steelcowboy on topic carb ports?
thank you guys i found this out on another web site that they where vents
