- Thank you received: 7
carb issue?
- toad
27 Apr 2009 09:38 #285676
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
carb issue? was created by toad
75 900
26mm carbs, 4-1 header, pods, coil mod and pretty much stock . my jets are 17.5 pilots with 117.5 mains and idles very nicely after its warmed up a bit.The only problem I get is when I really crank the throttle back in first gear for a wheelie or burnout and right after she bogs down like crazy for 5 or so seconds but other than than she goes like hell in the upper rpm range right thru to 11g, just curious what that could be.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- keith1
- Thank you received: 2
27 Apr 2009 15:54 #285784
by keith1
Replied by keith1 on topic carb issue?
do you know what the needles are clipped at?....and you spin it up to 11 grand?.....whats the redline at for that bike?.......keith
- toad
28 Apr 2009 07:20 #285957
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic carb issue?
well the redline starts at 8500 but she pulls right too 11000rpm, I dont know if I should screw with it or not it runs so good at Idle and high rpm any feedback would be greatly appreciated
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- timebomb33
- Thank you received: 10
28 Apr 2009 07:29 #285959
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic carb issue?
bump your idle up to 1200 or 1400 and try that i have almost the same set-up on my street bike and when i know i'm going to some crazy stuff i just bump up the idle ahead of time and it comes back no problem as for these things turning higher rpm's then stock my old bike i had a drl-200 rev limiter on it and it was set for 11000 rpm i used to launch the bike off the high end all the time as far as i'm concerned if the motor is built right it can and does handle it quite well by th way what the hell is a red line anyway it's more of a suggestion it's not like if you hit it or beyond the motor explodes never has with any of my stuff anyway my 1393 motor makes over 150 at 10250 so still is making good power high up.it may not be needed to go to those big rpm levels but it sure is fun! :woohoo: :woohoo:
