Help me diagnose please
- vincentmoy
26 Apr 2009 14:08 - 26 Apr 2009 14:10 #285428
by vincentmoy
1980
KZ750 LTD
Miles: Unknown (speedo cable broke)
Help me diagnose please was created by vincentmoy
So I just got a 80 KZ750H1 LTD. My 1st bike as I just got my permit. I am excited to save up some more $$ to get a MSF course.
kzrider.com/index.php?option=com_kunena&...=10&id=285331#285427
The bike will start and run but my roomate (as I am not confident enough to ride the bike yet) said the bike keep dying unless the rider keep giving gas. Choke position doesn't seems to matter although closing the choke (up position) seems to help a little bit.
Another problem is when you give it throttle, there is a sec or 2 delay that probably shouldn't be there. My roomate said it could also related to the carb.
I am new to mechanical stuff but I do have a few friends that may be able to help. I am wondering what are you guys' thought on this issue.
Thanks
Thanks
1980
KZ750 LTD
Last edit: 26 Apr 2009 14:10 by vincentmoy.
- PLUMMEN
- Thank you received: 104
26 Apr 2009 16:41 #285467
by PLUMMEN
Replied by PLUMMEN on topic Help me diagnose please
tune upwould be good place to start
- bountyhunter
- Thank you received: 337
26 Apr 2009 17:11 #285474
by bountyhunter
Replied by bountyhunter on topic Help me diagnose please
My recommends would be:
Tune up
Oil change
check valve clearance
clean carbs/fuel tank, and replace fuel filters
For starters, you might put some Seafoam cleaner in the fuel to try to get some of the deposits out of the fuel system.
Tune up
Oil change
- vincentmoy
27 Apr 2009 02:06 #285617
by vincentmoy
1980
KZ750 LTD
Replied by vincentmoy on topic Help me diagnose please
Well, a tune up on a car is to change spark plugs and wire. Is it the same as on a bike?
thanks
thanks
1980
KZ750 LTD
- brianpclarke
27 Apr 2009 03:07 #285621
by brianpclarke
A tune up on a car is very different than on a 28 year old motorcycle. The last thing you want to do is find yourself in a bad situation on 2 wheels because of a minor mistake, or a 10 dollar fix.
If you have a manual, than it will put it pretty clear what a routine tune-up is. However, there was a post on here recently under "Engine" labeled "Free Electronic Manuals".. go in there and under small engine - motorcycle -.... you will find your bike. Tells you everything you need to know as far as a tune up goes...
-Brian
1977 KZ650C
1976 Kz900 LTD
Replied by brianpclarke on topic Help me diagnose please
-Brian
1977 KZ650C
1976 Kz900 LTD
