CARB SYNC WITHOUT GAUGES
- killerkaw
26 Apr 2009 06:28
Ok I need to syncronize my carbs on my 750 twin with bs 34 carbs and my vacuum guages are crap bouncing all over the place I ordered another set last night. is there anyway to get it close so i can ride it today im sure its not advisable but is it possible thanks
- Mcdroid
- Gone Kwackers
Re: CARB SYNC WITHOUT GAUGES
26 Apr 2009 06:41
Yes, there is a way...go to your Kawasaki shop manual (99997-744-04), turn to page 15 and follow the directions...supposedly takes a special tool also.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- OKC_Kent
- Mark Wing
26 Apr 2009 10:29
You can hold a hose to your ear and the other end in the carb opening and listen , you should be able to hear if they sound the same. It's easy on my bike with no airbox.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Tony
Author
26 Apr 2009 10:42
OKC_Kent wrote:
I used one similar to this on my 750 twin and it worked fine.
- mtkawboy
26 Apr 2009 13:29
Before I had mu gauges I used to put a piece of wire under the slides and turn the carb so the inlet faced down and then turn the adjusters until the wire fell out on all the carbs
- killerkaw
30 Apr 2009 15:33
i made the sync tool just out of curiosity to check it out i used 1/4id hose not 1/8 as in the plans and it works really well i used it to set them and rechecked with a borrowed set of gages and it was spot on good idea allthough it cost around 7 dollars not 1.50 but still a bargin
- fochtup1
30 Apr 2009 18:21
OKC_Kent wrote:
any plans on one for a four cylinder or just do carbs 1&2, then 1&3 then 1&4 with a mark on the tubes at the first set of carbs to go by.
- N0NB
- Blue handles better
30 Apr 2009 20:14
I recently did a sync for a member of another forum. When he got here I found to my dismay that one of the tubes had broken (this was a Motion Pro mercury model). So I wound up doing two cylinders at once and used #1 as a baseline for the other three. It worked well and he says the bike is running great.
I'm not sure if I want to replace it with the yardstick model or one of the new Motion Pro models. I don't foresee a need for one for a while, though.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
