pingel fuel switch
  • rkan
  • rkan's Avatar Topic Author
pingel fuel switch
24 Apr 2009 08:59
#284765
MY '78 kz650's vacuum petcock is leaky and i think i just want to replace with a new pingel nonvacuum one. what is a good way to block the vacuum line on the carb so the mixture isn't too lean?
1978 KZ650B
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: pingel fuel switch
24 Apr 2009 09:12
#284771
You should be able to go to your local auto parts store and be able to pick up an assortment of vacuum caps.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • RonKZ650
  • RonKZ650's Avatar
24 Apr 2009 09:54
#284778
The vacuum cap is the best probably, but you can simply find a bolt the correct size and plug the line with that, or get a wooden dowell and plug it ect. Anything will work really.
  • rstnick
  • rstnick's Avatar
24 Apr 2009 11:06
#284800
You can get a dirrect fit replacement from Z1enterprises.
Check out this post, 2nd reply for links:
forums.kz650.info/index.php?PHPSESSID=f7...63193dd&topic=1221.0
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
