Have to run with choke on
- 1981KZ305
24 Apr 2009 08:23
I have a 81' KZ305. I've been thru the carbs and cleaned all of the ports and passages out and I have set the float height properly. My problem is that I have to run the bike with the choke partway on all the time or it runs lean and spits. I have checked for inlet leaks and found none. Could this be a diaphram problem?
- trianglelaguna
Re: Have to run with choke on
24 Apr 2009 09:00
sounds like you missed a tiny hole in the pilot jet....you can re-do it and use a strand of copper wire in a dish of carb cleaner and clear all brass orifices...careful that the wire does not kink or bind and get snapped.....that is a clogged idle jet imo.....good luck....when you take it off choke does it die......idle jet imo...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- 1981KZ305
24 Apr 2009 09:09
Yea, it wont idle below 2K with the choke off. Oh well, It only takes 10 minutes to get the carbs off and get em apart. Thanks!
- Bicycle Lee
16 May 2009 11:05
did you figure out the problem? I'm having the same issue with these vm28's I just installed... it looks like there's some fuel leakage so I kinda figured there was a vacuum problem....
I have a set of bs34's I might just run until I can get these 28's figured out....
1978 KZ1000 police
- Dragone
16 May 2009 13:28I have a set of bs34's I might just run until I can get these 28's figured out....
That sounds like a large tuning job on the switch to make it work for your application/riding.
- Bicycle Lee
16 May 2009 22:12
well, the 34's were on there when I got the bike so I wanted to get the 28's that came stock with it, but since these are acting up I'll just keep on using the 34's until I can afford to have them rebuilt. What's the issue?
1978 KZ1000 police
