Is it in the right hole?
- schast
23 Apr 2009 12:33 #284407
by schast
Is it in the right hole? was created by schast
I don't typically have to ask this question...
My KZ750M1 CSR-twin just had the carbs dipped and lots of internals replaced. Only problem is, that it's been so long since I took them off that I forgot which T-fitting is the fuel input and which is the overflow drain. Is it the one closer to the cylinders and higher than the one nearer to the airbox and near the bottom where the float bowl is?
I have it on the upper/front one now and it leaks fuel from some openings near the airbox intake side of the carbs. THey are Mikuni BS34 I believe.
Thanks,
Shawn
(yes I need a manual, if I had one I wouldn't have to ask)
Thanks,
Shawn
- Mark Wing
- Thank you received: 22
23 Apr 2009 18:39 #284576
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Is it in the right hole?
How about posting a pic.
Mark
Mark
Yorba Linda Cal.
- buckinrut25
23 Apr 2009 18:49 #284581
by buckinrut25
Replied by buckinrut25 on topic Is it in the right hole?
the line closest to the air box is the inlet
- trianglelaguna
- Thank you received: 235
23 Apr 2009 19:46 #284606
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Is it in the right hole?
buckinrut25 wrote:
that is my guess too..
1976 KZ900
2003 ZX12R
2007 FZ1000
- killerkaw
23 Apr 2009 19:49 #284608
by killerkaw
Replied by killerkaw on topic Is it in the right hole?
I have the same bike and walked out and looked it is the one in the rear closest to the airbox
- schast
01 May 2009 13:07 #286997
by schast
Replied by schast on topic Is it in the right hole?
Thanks guys. I ended up switching them before there was a reply and it works better now. I just need to understand now what adjustments I can make to help it run better so I can get it to the shop for a proper adjustment and synch. The hoses are all dry rotted and cracked too so after I replace them and figure out if I need to rebuild the petcock or not. Currently have to keep it on PRI(me) to stay running.
