Need help w/ sync!!
- Pro_window78
- MFolks
- Thank you received: 540
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Pro_window78
- Pro_window78
- dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Russ Jackson
Update: My gauges are antiques and COMPLETE crap! All they do is sit there and bounce at idle, they smooth out around 4k, but they all don't read zero at rest. Does anyone know of a decent set of gauges for less than an arm and a leg? Thanks:woohoo:
Are you looking for a Tach, Speedometer or both? I just bought a new set to change out mine because the trip meter doesnt work but everything else is fine. It has 32000 miles on it and the Tach works perfect....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- 88alltrac
81 KZ1000 K1
Lincoln NE
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- Pro_window78
