- Thank you received: 1
Only two
- poolboy
22 Apr 2009 10:18 - 24 Apr 2009 08:53 #284055
by poolboy
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
Only two was created by poolboy
Last edit: 24 Apr 2009 08:53 by kzrider. Reason: Missing topic
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
22 Apr 2009 10:22 #284057
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic Only two
Valve clearances? Compression readings?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- rstnick
- Thank you received: 377
22 Apr 2009 10:36 #284058
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Only two
Is one coil's spark plug wires going to cylinders 1&4 and the other set of wires from the other coil going to cylinders 2&3 ?
If you have them like this and she wont work, try switching the green and black wires that are going to the coils. These are the wires coming from the IC Igniter. You may have something reversed here.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Thank you received: 2098
22 Apr 2009 13:18 #284096
by Patton
Replied by Patton on topic Only two
Would also remove plugs and visually inspect spark quality, especially #3/4 plugs.
Good Luck!
Good Luck!
- poolboy
22 Apr 2009 15:07 - 22 Apr 2009 19:57 #284126
by poolboy
Replied by poolboy on topic Only two
Last edit: 22 Apr 2009 19:57 by poolboy.
