VM24SS pilot circuit question
- jzanutto
22 Apr 2009 08:26 #284034
by jzanutto
1978 KZ650B 2004 BMW R1150RT
VM24SS pilot circuit question was created by jzanutto
OK, another basic question on my stock VM24SS carbs on the 78650B.....
all the books show an actual pilot screw and recommend a setting for it. Mine just have a hole there that is capped off way down in the hole, and I have the low speed air screws.
My assumption is that I have California specific carbs???
- RonKZ650
- Thank you received: 240
22 Apr 2009 10:10 #284053
by RonKZ650
Replied by RonKZ650 on topic VM24SS pilot circuit question
No some 78 KZ650s used pilot screw type with the screws adjusted below the carbs, some used air screw type with the screws on top of the carbs. I have 2 1978 KZ650s bought right here in Colorado, and one has pilots, one has air screws. The air screws are much easier to work with. The air screws let more air in leaning the mixture as they are turned out. About 1 1/2 turn out is a good starting point. The pilots let more fuel in if you turn them out richening the mixture, so the 2 types are exact opposite in how they tune.
- jzanutto
22 Apr 2009 10:15 #284054
by jzanutto
Replied by jzanutto on topic VM24SS pilot circuit question
thanks, I understood the principle behind the 2 types, but wasnt sure why I had them
- jzanutto
22 Apr 2009 10:44 #284061
by jzanutto
the pilots are only available in 2.5 increments.. So the suppliers show 15, then 17.5
has anyone run a 17.5 on a 650 with pods and kerker???
- rstnick
- Thank you received: 377
22 Apr 2009 10:51 - 22 Apr 2009 10:52 #284064
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic VM24SS pilot circuit question
Check out this post on what other 650 riders are using for jet sizes with different set ups:
forums.kz650.info/index.php?topic=1853.0
Also some other info in the carb section on the different carbs used and tuning.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 22 Apr 2009 10:52 by rstnick.
- jzanutto
22 Apr 2009 12:57 #284090
by jzanutto
ok which way are you guys counting needle grooves??? Is #1 the bottom groove or the top groove??
- OnkelB
- Thank you received: 80
22 Apr 2009 14:00 #284103
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic VM24SS pilot circuit question
Top groove (away from the tapered end) is # 1.
