82 r1 carbs
  • shane99
  • shane99's Avatar Topic Author
82 r1 carbs
21 Apr 2009 02:50
#283587
can anyone send me a diagram of correct hose routing, including vacuum hoses for my 82 750 r1. no fuel going to carbs 3 & 4. can't find diagram anywhere. thanks
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 82 r1 carbs
21 Apr 2009 06:29
#283617
I'll take a peek at the KHI shop manual when I get home this evening to see if there is anything diagramed.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • shane99
Re: 82 r1 carbs
21 Apr 2009 14:15
#283738
thanks.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 82 r1 carbs
22 Apr 2009 06:00
#284003
shane99...the Kawasaki shop manual has nothing regarding hose routing and the exploded diagrams on the Kawasaki site aren't much more help. Ley me look at my R1 tonight and see if I left things hooked up before I mothballed it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • shane99
Re: 82 r1 carbs
22 Apr 2009 09:32
#284042
thanks i appreciate the effort
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 82 r1 carbs
23 Apr 2009 07:22
#284362
Shane, I think there is only a single fuel line going to the carbs but there are three vacuum hoses coming off the carb bank. One of mine isn't connected to anything but the other two come off each end of the carb bank, meet at a 'T' over the carbs with a single vacuum hose then extending to the pollution control device over the exhaust side of the cam shaft cover.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • shane99
Re: 82 r1 carbs
02 May 2009 05:36
#287138
thanks for your help. i ended sending them out and getting them cleaned and rejetted. came back with hoses on properly. i'm going to take a picture so it doesn't happen again.
shane
  • mbsween
  • mbsween's Avatar
Re: 82 r1 carbs
03 May 2009 19:59 - 03 May 2009 20:00
#287684
Shane,
Take a look here
kz.mbsween.com/parts/C-9AirCleaner.jpg
You'll see the vacuum lines diagrammed in the upper left. They don't show the connections to the carbs, but after years of removing them I can replace them in my sleep. From carbs 1 and 4 you go to the T which then goes to the clean air rig under the tank/coils. 3 has a cap that effectively plus it. and 2 goes to the petcock.
If you don't have the plug you can use a small length of vacuum hose and a bolt to plug it.
If the clean air assembly was removed from your bike you can just connect 1 and 4 together or plug those also.
Almost forgot, the gasline (1) goes from the Petcock to the a fitting between carbs 2 & 3.
That site kz.mbsween.com has the parts microfiches for the 83 KZ750L which is mostly the same as the 82 R1 (I own both). From a parts perspective, they're the same except for the gauges, handle bars, color of gas tank/side panel/tail piece, and chrome bits vs black on the engine covers.
HIH
Matt
Last edit: 03 May 2009 20:00 by mbsween.
  • thompsonmx100
  • thompsonmx100's Avatar
Re: 82 r1 carbs
04 May 2009 18:23
#287979
hey do any of you guys know of a good place to get carb rebuild kits for a gpz 750. Other than the stealership
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
