Slides binding after carb cleaning
- lg_rebel
20 Apr 2009 23:27 #283564
by lg_rebel
Slides binding after carb cleaning was created by lg_rebel
I have a 79 KZ1000e with the VM28SS carbs. When I reassembled the carbs after cleaning, I turned the cable pulley by hand to check proper function. The slides moved open and snapped back shut like they were supposed to. However, after doing this a few times, they slides began to bind and they would not close on their own. I've removed and reassembled the slides a few times and keep having the same problem. Anyone have a solution or suggestion for this issue? Thanks
- timebomb33
- Thank you received: 10
20 Apr 2009 23:31 #283566
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Slides binding after carb cleaning
sounds like the throttle linkage is binding up did you have the carbs apart completly. if so double check against the manual to make sure you have everything as it should be.
- wizardofoz
21 Apr 2009 00:00 #283575
by wizardofoz
Replied by wizardofoz on topic Slides binding after carb cleaning
Polish the slides & bores with 'T' Cut.
- keith1
- Thank you received: 2
21 Apr 2009 14:19 #283742
by keith1
Replied by keith1 on topic Slides binding after carb cleaning
a light coat of grease on throttle shaft before you run it through woud nt hurt either.....i think my manual says to......
- Jeff.Saunders
21 Apr 2009 14:35 #283748
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Slides binding after carb cleaning
Did you keep track of which slide came out of which carb body? Sometimes you get a little wear on the slides - and putting them in different bodies causes them to bind a little.
Z1 Ent on Facebook,
