1980 kz1000b4 ltd
- insanelane
- roy-b-boy-b
- Thank you received: 103
I would raise the needles. Roy
- insanelane
- keith1
- Thank you received: 2
Yes they are B8ES. How hard is it to raise the needles and is that going to screw up my syncronization of carbs? Arent the needles under the synchro. adjusters on the vm28mm carbs?
i would 4th clip the needle...that might have you going back down in main jet to 117.5 or 115....you are gonna have to pull carb tops and pull throttle shaft and pull slides out...once you get em out, look down inside slides you removed and you will see 3 small screws....CAREFULLY unscrew those and everything will be clear....you will have to bench sync...4th clip is four down from top out of the 5 grooves...good luck......
- insanelane
- keith1
thanks ill give it a try
i forgot to mention to pull the two rubber plugs, one on each side of the outboard carbs....good luck and let us know how ya make out....keith
- sbulla
- 1980 KZ1000 LTD
I didnt do anything with the needle jets as far as moving the clips, probably in stock position. Do I need to jet higher. or could it just be the needle position. Thanks
I have the same bike and carbs and, my needles aren't adjustable as far a moving the clips. There is only one groove.
Maybe, you have an aftermarket needle if it has more grooves.
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
- racer54
- Thank you received: 114
- dodak1967
- sbulla
- 1980 KZ1000 LTD
If you have non-adjustable needles, just place a washer of a thickness you think would be needed to raise needle under the clip on there now. Lots of guys have got around that issue this way.
That's so simple, I would have NEVER thought of it!
Thanks,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- larrycavan
- Visitor
There's absolutely no way a 102.5 main jet will work with the airbox gone. Go straight to at least 115....more like 120 and work from there.
All through the KZ years, Kawasaki kept leaning out the midrange from year to year....model to model..
You can shim the needle up as suggested. You could also try a 5DL-31 Needle.
If it's not surging any when cruising at a steady throttle opening and the plug insulators show no sign of blistering then you really are not in any danger of an over lean condition.
Look at the flat base ring of the plug where the threads end. The ring the ground strap is welded to. That's where you want to read your jetting. If there's no color there, it wants some more fuel.
If the bike runs strong, shows no indication of a dangerous lean condition and you don't want to disturb the carb synch, go to B9ES plugs and see how they look...
Back in 80, when those bikes were brand new, the plugs would normally show a white inslulator, even with the stock air box.
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
I forget what my primaries are but I went with 117 mains. Never touched the needles.
Runs just a tad rich, but I tend to think my motor might last a little longer that way.
