1980 kz1000b4 ltd
19 Apr 2009 10:27 #283082 by insanelane
1980 kz1000b4 ltd was created by insanelane
I just installed emgo pods and vance and hines megaphone 4-1 pipe. It has 28mm VM mikunis with acc. pump. I also just did the W.G. coil mod. I am running #20 pilot jets and #120 main jets. The bike runs good and very,very strong but my plugs are also very white on the inner porcelian. I didnt do anything with the needle jets as far as moving the clips, probably in stock position. Do I need to jet higher. or could it just be the needle position. Thanks
19 Apr 2009 11:19 #283090 by roy-b-boy-b
Replied by roy-b-boy-b on topic 1980 kz1000b4 ltd
Are your plugs B8ES?
I would raise the needles. Roy
19 Apr 2009 16:53 #283142 by insanelane
Replied by insanelane on topic 1980 kz1000b4 ltd
Yes they are B8ES. How hard is it to raise the needles and is that going to screw up my syncronization of carbs? Arent the needles under the synchro. adjusters on the vm28mm carbs?
19 Apr 2009 18:22 #283160 by keith1
Replied by keith1 on topic 1980 kz1000b4 ltd
i would 4th clip the needle...that might have you going back down in main jet to 117.5 or 115....you are gonna have to pull carb tops and pull throttle shaft and pull slides out...once you get em out, look down inside slides you removed and you will see 3 small screws....CAREFULLY unscrew those and everything will be clear....you will have to bench sync...4th clip is four down from top out of the 5 grooves...good luck......
19 Apr 2009 18:44 #283169 by insanelane
thanks ill give it a try
19 Apr 2009 18:50 #283172 by keith1
i forgot to mention to pull the two rubber plugs, one on each side of the outboard carbs....good luck and let us know how ya make out....keith
19 Apr 2009 20:01 #283201 by sbulla
Replied by sbulla on topic 1980 kz1000b4 ltd
I have the same bike and carbs and, my needles aren't adjustable as far a moving the clips. There is only one groove.
Maybe, you have an aftermarket needle if it has more grooves.
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
19 Apr 2009 20:28 #283214 by racer54
Replied by racer54 on topic 1980 kz1000b4 ltd
If you have non-adjustable needles, just place a washer of a thickness you think would be needed to raise needle under the clip on there now. Lots of guys have got around that issue this way.
20 Apr 2009 01:18 #283267 by dodak1967
Replied by dodak1967 on topic 1980 kz1000b4 ltd
I also have an 80 kz1000b4ltd. Ive thought about installing air filter pods but I heard that they can cause some negative performance issues and to stick with the stock airbox assembly. Has anyone experienced any problems using the open element air filters and what was done to rememdy the issues?
20 Apr 2009 05:52 #283277 by sbulla
That's so simple, I would have NEVER thought of it! :P
Thanks,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
  • larrycavan
  • Visitor
20 Apr 2009 07:21 #283295 by larrycavan
Replied by larrycavan on topic 1980 kz1000b4 ltd
The stock needles should be 5CN-29 and they have a pretty lean O-1 needle jet in those carbs. Stock main jet was a 102.5.
There's absolutely no way a 102.5 main jet will work with the airbox gone. Go straight to at least 115....more like 120 and work from there.
All through the KZ years, Kawasaki kept leaning out the midrange from year to year....model to model..
You can shim the needle up as suggested. You could also try a 5DL-31 Needle.
If it's not surging any when cruising at a steady throttle opening and the plug insulators show no sign of blistering then you really are not in any danger of an over lean condition.
Look at the flat base ring of the plug where the threads end. The ring the ground strap is welded to. That's where you want to read your jetting. If there's no color there, it wants some more fuel.
If the bike runs strong, shows no indication of a dangerous lean condition and you don't want to disturb the carb synch, go to B9ES plugs and see how they look...
Back in 80, when those bikes were brand new, the plugs would normally show a white inslulator, even with the stock air box.
  • riverroad
  • 1980 1000LTD B4
20 Apr 2009 07:44 #283299 by riverroad
Replied by riverroad on topic 1980 kz1000b4 ltd
Mines a 1980 B4 also, with Emgo pods and a Mac Header. Took me a couple tries to get her dialed in, but I finally did.
I forget what my primaries are but I went with 117 mains. Never touched the needles.
Runs just a tad rich, but I tend to think my motor might last a little longer that way.
