- Thank you received: 2098
ready to toss a match in my fuel tank!
it rained today so i didnt get any pics but i got another question. we have a kawi LTD750 sittin in the garage at my parents place.is that a KZ750 by chance? they look similar.
Could be, as LTD models of the KZ750 were produced for several years.
Pic? Vin? Info on triple clamp?
Good Luck!
- 2low4NH
how many parts could be interchangable?
Am uncertain as to which KZ750 parts might be interchangeable with 1983 KZ550.
Good Luck!
- 2low4NH
- 2low4NH
- 2low4NH
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- JMKZHI
- Thank you received: 48
The KZ 2-cylinder motorcycles are parallel Twins.2low4NH wrote:
what do you mean by twin? as in a v twin motor? its a 4
It's an air injection system - fresh air is introduced into the exhaust to help burn off any unused fuel..... u said the emmisions part which im guessing kinda works like a pcv has a big hose off the airbox and is mounted under the tank!
Actually, you have two air injection lines connected to the #1 & #4 carb holder vacuum ports... Referencing your pics above (they would be easier to look at if the pics were oriented the same, instead of having one sideways. ) The #2 & #3 carb holder vacuum ports are typically capped. Please note that those ports are NOT on the carbs.should have 2 vaccuum lines going to it right? i have one line coming off the 1st carb.
The vents are usually located in the same position on two of the carbs - probably the #2 & #4 carbs - the blue cap in pic one, the open port yer pointing to in pic two. The vent tubing is routed towards the rear of the bike & should point down. On my bike they're routed over the airbox shoulders & fit snug between the airbox & side covers.
I would guess that the petcock vacuum line is connected to the forward port on carb #4 in pic one.
- JMKZHI
The carbs etc are numbered 1-2-3-4 left-to-right sitting on the bike.
Carb holder vacuum ports:
#1 & #4 -->> air injection system hoses
#2 & #3 -->> capped
Carb vents:
#2 & #4 -->> same general postion on those two carbs
The blue cap & the one yer pointing to. The vent hoses are typically routed towards the rear of the bike & should point down.
Petcock vacuum port:
#4 -->> the forward port w the black tubing.
Fuel line:
Connected to a T-fitting between #2 & #3
- Thank you received: 2237
- 2low4NH
- JMKZHI
Confused!?!?! If you mean the vent ports on the #2 & #4 carbs, then yes, they should be open to the atmosphere. Route the tubing in whatever manner is correct for your bike.....the pics with the blue cap are 3/4 so those should be open? ...
And I forgot to add in my first post that the 550 is completely different than the 750-4.
