Difficult to start in cooler weather
- franknsr
18 Apr 2009 07:21 #282794
by franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
Difficult to start in cooler weather was created by franknsr
Oh internal combustion gurus, I need your help. Carburetion is my Achilles heels so any advice is sincerely appreciated.
My bike simply does not like to start if it’s cold outside. Once it drops to about 40 degrees F/ 5 degrees C, by bike just does not want to start. If I get jumper cables and starting fluid I can get her running after about 30 minutes of screwing around. If it’s below about 30 F/0 C, forget it. Ain’t happening.
The choke seems to work, but doesn’t do much. I installed a primer and that helps, but if it’s cold outside it gets very difficult.
The bike is an 82 650 with Mikuni CV carbs, no airbox 4 pods. Going back to the stock airbox is not an option but if that is the issue I cab fab one up, or swap carbs out. Yes, yes I know, I am a flippin idiot for cutting the frame up so the stock airboxes won’t fit but this is where I am at. Any suggestions are appreciated.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- anarki650
- Thank you received: 5
18 Apr 2009 07:59 #282804
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Difficult to start in cooler weather
Nice work heading off the "ditch the pods and put the stock airbox back on"!!! LOL
I've been running pods on my 77 kz650 since I've had it and she's always been an easy start. Not sure what all you've done, but the steps I followed to get her where she is are:
1. Check compression. Bike's going to run like shit if you don't have good compression on all cylinders. It's just that simple.
2. Check valve clearances. Bike will run like shit if they're out of whack. No way around that.
3. Ensure timing is dead on and you have good spark reaching the cylinders.
4. Adjust carb jetting/adjustments/sync LAST. If you don't have the other three areas guaranteed in spec and properly functioning you'll NEVER get your carbs right.
If you go through all these steps, or have recently enough that you know everything is right, getting the bike to run good with pods cold/hot/everywhere in between is just a little patience and tuning away. My 77 is a two kick start after sitting for 3 weeks of sub zero overnights this winter, so don't let anyone try to convince you that pods are the devil and you'll never get the bike running right with pods on it...
09 Kawasaki ER6n
Omaha NE
- PLUMMEN
- Thank you received: 104
18 Apr 2009 08:04 #282805
by PLUMMEN
Replied by PLUMMEN on topic Difficult to start in cooler weather
i dont start well below 40 degrees either! :laugh:
