what 28mm carbs will fit my 650?
- judgie
17 Apr 2009 02:09 #282527
by judgie
forever tweeking aircooled engines, well it is my job
77 z650c1
what 28mm carbs will fit my 650? was created by judgie
building up the z650 motor with some high lift cams , ported head and a small bump in c/r. has kerker pipe
by my calculations i need some 28mm carbs for max power from the combo i'm running.
what do i need and from what bike am i going to find them on?
77 z650c1
- anarki650
- Thank you received: 5
17 Apr 2009 04:51 #282536
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic what 28mm carbs will fit my 650?
Mikuni vm28 carbs would be the way I'd go. They came stock on the early z1 (some of these parts are hard to come by though so I'd look for a later set), also on some of the kz900/1000 bikes (sorry, don't know for sure what years/models came with the 28s and what came with 26s) Your carb body spacing will be the same on any of these and will match the intake spacing on the 650's head. You will need to get bigger carb holders. Get them for a late kz900 (IIRC I bought them for a 77 kz900 when I put my 26s on my 650). You'll also have to slot the mounting holes on the carb holders so they'll bolt up to the 650's head, and sand off the "lip" on the back side of the carb holder that rests inside the 900/1000 head. Use a light layer of black silicone between the surfaces to ensure a good mating.
09 Kawasaki ER6n
Omaha NE
- otakar
17 Apr 2009 05:51 #282545
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic what 28mm carbs will fit my 650?
The 78 Z1R also came with 28s and so did some of the later bikes before they went to CVs
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Nebr_Rex
- Thank you received: 300
17 Apr 2009 07:01 #282565
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic what 28mm carbs will fit my 650?
550, 650, 750, 900 and 1000 have the same spacing
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- otakar
17 Apr 2009 07:20 - 17 Apr 2009 07:22 #282567
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Not the 550. those are quite a bit closer together. The 550 however has the same spacing as the 750 zephyr. What is nice is to get a set of 750 Zephyr Manifolds and mount a set of CVK 32mm Keihin's on the bike. The manifolds will bring the spacing down to the 550 spacing. There is where you get the real nice performance. That is a nice mod for any 650-900 engine. Maybe even larger.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Apr 2009 07:22 by otakar.
