idle/backfire issues
- soccerd31
15 Apr 2009 09:06 #281955
by soccerd31
1981 KZ750 LTD H2
idle/backfire issues was created by soccerd31
i have an 81 kz750 h2... i'm having a problem with my idle... SOMETIMES it wants to run high (3000 rpm+) and it usually comes after running the engine high accelerating... i noticed that if i push down on the carb unit (filter side) the idle returns to normal (1000-1250 rpm)... i think i need new carb holders but.... not quite sure... i've put seafoam in my tank (1/3 can... been in for about a week) and have removed my filters and sprayed some carb cleaner in them...
also i've been getting backfires out of carbs 3 and 4... donno if this has anything to do with it..
tips/suggestions???
thanks!
tips/suggestions???
thanks!
1981 KZ750 LTD H2
- MFolks
- Thank you received: 540
15 Apr 2009 09:31 #281962
by MFolks
Replied by MFolks on topic idle/backfire issues
Have you checked the input voltage to the ignition coils? It should be the same as battery voltage. If it is a lot less, you might consider doing the "Wired George" ignition relay bypass modification. His website
lists parts and how to do it.
- buckinrut25
19 Apr 2009 14:16 #283116
by buckinrut25
Replied by buckinrut25 on topic idle/backfire issues
i would start with the vaccum lines with a small leak the idle will be eratic and rev up and cause a lean condition wich may explain the poping or back fire in the exhust might be a cheap fix and were id start
- AXL
20 Apr 2009 17:19 #283418
by AXL
Replied by AXL on topic idle/backfire issues
is that the same repair for backfiring through the exhaust and flames? should I look for a leak in the vacuum lines? can't find any vacuum lines to look at?? the engine is a 77 KZ1000.
- timebomb33
- Thank you received: 10
20 Apr 2009 17:27 - 20 Apr 2009 17:28 #283421
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic idle/backfire issues
it sounds like you need to replace yor intake manifolds air leaks will cause erratic idles and it will cause the engine to not return to idle properly. the backfire is caused by a lean mixture which is a symptom of leaking intakes
Last edit: 20 Apr 2009 17:28 by timebomb33.
