brainstorm fuel injection
- School Teacher
I know the spacing would be off, but i can make that work. what would i need to look out for? what cc bike would i take it off of? because the newer bikes rev higher/breath better etc.
any way this is something that have most the parts(not fuel system tho) for just need the time to put it together so i'm looking for suggestions and ideas brainstorm away guys!
thanks
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- PLUMMEN
- Thank you received: 104
- pchavez
Maybe something like that? Injectors are expensive though.
77 KZ650 - stock | 93 KZP1000 - project X!
- MFolks
- Thank you received: 540
www.diyautotune.com/catalog/index.php
www.msefi.com/viewtopic.php?f=29&t=6627
www.dropbears.com/bikelinks/Parts/Fuel/fuel2.html
www.dobeckperformance.com/default.asp
On the FI 81 and 82 GPZ 1100's a fuel pump pressurized the injectors to 33-35 PSI with low amp draw. I think the MSD #2225 fuel pump might work if you can't get a Kawasaki pump.
The GPZ's had several sensors(on my 82 there is a throttle position sensor at the end of the throttle shaft,an engine temp sensor screwed into the engine block under the #1 throttle body, and an air temp sensor in the air filter housing area).
- T_Dub
- Thank you received: 25
With regards to sensors, you'll have to mount up a TPS, MAP, air temp, and oxygen I'd imagine, whatever is on the donor bike.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- School Teacher
1980 kz1000G1
- School Teacher
Do i pick by mm dia? cuz 600cc bikes seem to be at38mm and bigger bikes seem to be 42-46 range?Here's some related websits for FI:
1980 kz1000G1
- T_Dub
They have showerhead injectors that spray into the throat at high rpm. These are from a CBR600RR.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- School Teacher
Yeah maybe some 600 dual stage carbs would be good, such as:
thanks sounds like they could work:)
1980 kz1000G1
