- Thank you received: 4
BS34 Throttle Bodies
- KawiConvert
13 Apr 2009 22:19 #281571
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
BS34 Throttle Bodies was created by KawiConvert
Are there any differences between BS34 throttle bodies? Specifically, how much interchanges between BS34's used on the KZ or GS or GPZ models. I have some carbs from a GS and will be getting some GPZ carbs and wondered what will cross over.
Thanks,
KC
Thanks,
KC
- otakar
14 Apr 2009 04:57 #281607
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic BS34 Throttle Bodies
First of all there are a couple of different BS34. Second of all GS bodies are different, because they are made for different spacing so the butterfly section is a different width. ON the KZ750/1000/1100, if they look the same they are. However the slide assemblies may be different. When we speak of bodies we are speaking of the empty casting only plus butterflys, since they are theoretically non removable.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
