- Thank you received: 6
29mm Smoothbore parts?
- badrhino
13 Apr 2009 19:13 #281491
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
29mm Smoothbore parts? was created by badrhino
Where does a guy get rebuild kits or gasket kits for the 29mm Smoothbore carbs?:blink:
Franken Z!
- badrhino
14 Apr 2009 08:19 - 14 Apr 2009 08:20 #281643
by badrhino
Franken Z!
Replied by badrhino on topic 29mm Smoothbore parts?
WHAT NOBODY ON HERE HAS A CLUE?
Franken Z!
Last edit: 14 Apr 2009 08:20 by badrhino.
- jzanutto
- lewisj
- Thank you received: 12
14 Apr 2009 08:50 #281651
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
Replied by lewisj on topic 29mm Smoothbore parts?
try Zi Enterprises under the kawasaki "site guide" for carbs. They have an extensive list of gaskets, jets, floats, needles and o-rings for the 29MM's. I just rebuilt mine and their prices were much better than others I found.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- tunafrieda
14 Apr 2009 09:08 #281656
by tunafrieda
Replied by tunafrieda on topic 29mm Smoothbore parts?
first:
z1enterprises.com/
call and ask to speak to jeff.
just because it's not on the websight does not mean he don't have it.
second:
try waiting more then 12 hours for a reply before you come running in with your caps on.
99.9% of the questions get answered her if you have a little paitence.
or maybe try bumping your own thread by adding to the question.
z1enterprises.com/
second:
- PLUMMEN
- Thank you received: 104
14 Apr 2009 09:35 - 14 Apr 2009 09:35 #281665
by PLUMMEN
Replied by PLUMMEN on topic 29mm Smoothbore parts?
chapstick on both sides of gaskets will keep them from sticking to bowls/bodies,dont ask how i learned this! :blink: :woohoo:
Last edit: 14 Apr 2009 09:35 by PLUMMEN.
- Russ Jackson
14 Apr 2009 09:39 - 14 Apr 2009 09:40 #281669
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic 29mm Smoothbore parts?
I recentley replaced some parts on my 29s.
z1enterprises.com/
had the parts I was looking for. Also when searching the site some parts were a little tough to track down. So if you dont see them just call them. Sudco has a great exploded view of that carb also and have most parts also. This site was also very helpful on re-jetting and several threads can be found about these carbs by searching smoothbores, smoothbore and 29mm. They can also be a little tricky to dial in correctly so have all your information handy. Ex: Headers, air-filters, big bore kit, etc.....Russ
Last edit: 14 Apr 2009 09:40 by Russ Jackson.
- badrhino
14 Apr 2009 13:09 #281748
by badrhino
Franken Z!
Jeeze, Sorry I scared you with the CAPS! LOL
Franken Z!
