Spewing carb
- lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- taildragger1197
- Thank you received: 17
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
- lapeerray
- Thank you received: 2098
any idea how to unstick it or do i need to pull carbs?
While it's spewing with engine running, rap smartly and repeatedly against the float bowl on the offending carb with a plastic mallet or large screwdriver handle.
This often clears the obstruction at the float needle/seat interface or releases a "stuck" float.
Good Luck!
Good Luck!
- Thank you received: 2829
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- ccrydercu
- lapeerray
- lapeerray
- lapeerray
should i put an inline filter in?
Yes. The inline filter is superior to the petcock filter which is basically just fine screen.
If twin fuel lines are fitted, use two inline filters. All fuel from petcock should pass through an inline filter before entering the carbs.
Good Luck!
