Changing Pod Filters
  • gaillarry
  • gaillarry's Avatar Topic Author
12 Apr 2009 11:27 - 12 Apr 2009 11:57
#280989
Had Emgo pod filters on my kz550 and the bike ran great, but switched to XS pods which are a lot larger. Now the bike is bogging down off throttle. It starts and idles ok but when giving it throttle is just bogs and stalls. Have the mix screws at 1.5 turns out.
1977 KZ1000
1985 Gpz750
Last edit: 12 Apr 2009 11:57 by gaillarry.
  • taildragger1197
  • taildragger1197's Avatar
Re: Changing Pod Filters
12 Apr 2009 12:16
#281006
You are getting a lot more air so now you need more fuel. Sounds like you need bigger main jets or maybe try raising your needles. I would install an aftermarket needle/jet kit.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
12 Apr 2009 14:24
#281044
Could re-adjust side-located mix screws to 1.25 turns out from lightly seated, and test run for effect. Repeat at 1 turn out from lightly seated.
If fitted with pilot mixture screws, go the opposite way, first 1.75, then 2.
If the pods require oil, would assure there're not over-oiled or under-oiled.
Good Luck! :)
  • loudhvx
  • loudhvx's Avatar
12 Apr 2009 14:44
#281050
Also, some types of pods sometimes cover some of the ports near the mouth of the carbs. Make sure none are blocked especially if you have CV type carbs. Which 550, by the way?
  • gaillarry
12 Apr 2009 15:21
#281063
It's an 82, had pods on it when purchased. Can't see the XS pods blocking anything. I'll adjust the mixture screws (on engine side) between 1 and 3 and see what happens. The carbs have 112.5 Mikuni main jet, 32 pilot and 64 secondary main jet. Needle is has a circlip on the 2nd groove from the bottom
1977 KZ1000
1985 Gpz750
  • kz550jc
  • kz550jc's Avatar
13 Apr 2009 07:38
#281349
dude i have a 1981 kz550 ltd i wanna change to pod filter any suggestions
  • gaillarry
13 Apr 2009 18:41 - 13 Apr 2009 18:42
#281480
I had Emgo filters but went to a bigger,better construction XS filter. Finally solved the problem bogging down, adusted the screws to 3/4 turns out, but I'm ordering bigger main jets.The XS filters are half the price of K&N.
1977 KZ1000
1985 Gpz750
Last edit: 13 Apr 2009 18:42 by gaillarry.
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
13 Apr 2009 19:44
#281508
where did you get the filters?
i need a new set ;)
  • gaillarry
14 Apr 2009 02:55
#281601
Ordered them from the local Honda shop, they're available from MC Distributing.
1977 KZ1000
1985 Gpz750
  • dshelly
  • dshelly's Avatar
14 Apr 2009 07:29
#281631
I picked up a set of those on ebay last fall from a guy, I think they were around $60. Brand new. :)
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • kz550jc
  • kz550jc's Avatar
14 Apr 2009 10:04
#281675
is there a specific size or its one size fits all
